2012martin wrote:
Hi Martin. Is the DVDlayer the same on the 32 vs the 40?
The DVD mechanism appears to be identical, although I haven't yet tried fitting it as I need to wait until I have some assistance before trying to lift my BV7-40 down from its wall bracket!.
I seem to recall reading somewhere that this was one of the changes between BV7-32 mk2 and mk3 (ie they switched to using the same mechanism as was in the 7-40)
2012martin wrote:
I have big swirl marks on my contrast screen caused by someone using some sort of cleaning fluid it's ruined the tv and I've been after a new contrast screen for some time but am yet too see one on eBay. Is the contrast screen in good condition? Would you consider selling me the contrast screen and I will pay for postage and packaging also?
The contrast screen has a 2 inch scratch on the left hand side, made worse by the fact that it looks like someone has removed more of the coating around the scratch by rubbing at it (photos below)
It is in the black border around the outside of the screen rather than within the display area though, so you may decide this is better than what you have now.
I'll leave you to decide on that one and offer you first refusal on having it for the cost of postage. I've got some spare plywood kicking around and if you do want it I think the best way I could package it would be to wrap it first and then cut a couple of sheets of ply to protect and reenforce it during transit.
Kind Regards,
Martin.
Login to view image
Login to view image Login to view image
