Anyone need any parts from a BV7-32 mk3?
Hi All,
I acquired a broken BV7-32 mk3 as I needed a replacement DVD mechanism for my BV7-40 and wanted to change the surround colour on my own BV7-32.
This does however mean I have a lot of other spare parts left over, so if anyone requires any parts please let me know.
I'm happy to post bits out or they can be collected from Exeter (I'm not looking for any payment - just cover the cost of postage)
Kind Regards,
Martin.
Hi Martin. Is the DVDlayer the same on the 32 vs the 40? I have big swirl marks on my contrast screen caused by someone using some sort of cleaning fluid it's ruined the tv and I've been after a new contrast screen for some time but am yet too see one on eBay. Is the contrast screen in good condition? Would you consider selling me the contrast screen and I will pay for postage and packaging also?
Thank you
David Martin
I'm interested in LCD if is in perfect condition and alu frame too.
i will provide collect by my courier.
Pls mail me.
Andrea
I'm nterested in the DTV tuner if it has one?
Hi Martin,
Do you need the dvd controlbox? Or have you have the old one as spare
I'm interested in that part.
Would be very nice!
Costs and extra will be payed in advance
Thanks,
Beobuddy.
Anti-reflective glass. Mine has 1 broken corner.
The DVD mechanism appears to be identical, although I haven't yet tried fitting it as I need to wait until I have some assistance before trying to lift my BV7-40 down from its wall bracket!.
I seem to recall reading somewhere that this was one of the changes between BV7-32 mk2 and mk3 (ie they switched to using the same mechanism as was in the 7-40)
The contrast screen has a 2 inch scratch on the left hand side, made worse by the fact that it looks like someone has removed more of the coating around the scratch by rubbing at it (photos below)
It is in the black border around the outside of the screen rather than within the display area though, so you may decide this is better than what you have now.
I'll leave you to decide on that one and offer you first refusal on having it for the cost of postage. I've got some spare plywood kicking around and if you do want it I think the best way I could package it would be to wrap it first and then cut a couple of sheets of ply to protect and reenforce it during transit.
Kind Regards,
Martin.
Pls mail me.
Andrea
It has a black frame and I'm intending to replace the Alu frame on my 7-32 with this, but I want to keep my old frame in case I decide to swap back at any point.
I'm honestly not sure if the LCD works or not. The TV had a display fault, but I'm not sure if this is the LCD at fault or the electronics which drive it. The TV appeared to work normally, ie I could change sources, and hear sound, and when powered on the backlight would come on, the screen would be blank, then at the point when the curtains would normally open, the display would change to what is pictured below, with a sparkling effect (ie many of the pixels randomly changing colour)
Maybe others might have some thoughts on where the fault might lay.
Anyway, if you want to try the LCD panel you're very welcome to it.
Kind Regards,
Martin.
I believe this is a DVB-T tuner. It has part number 8052265 on the plastic frame and 8080109 on the lower PCB if this helps.. There isn't a 7-32 mk3 service manual on the site so it's difficult to check many of the module part numbers.
It's yours if you want it.
Kind Regards,
Martin.
Kind Regards,
Martin.
That would be great! Happy to pay for your time as well... I'll send you an email.
Kind regards,
Jonathan
