Point taken, rechecked and remeasured anything I touched, and it all checks out.
That the amp sounded perfect for several minutes untill poof in my mind attests to a correct pre-amp job, else in my mind it would have sounded crap.
I left it on long enough also to mkae the idle current measurments. No fuses blow or anything like that.
And when I now measure the two pieces of what is left of that 470ohm resistor I have 54 volts over it. It leads me to suspect those largish resistors and that point-2-point network next to the large caps.
The caps themselves checkout, and that the rightside is getting correct voltages and is fine seems to indicate correct rectification and supplyvoltages exist. So my only though left is where the supply of power separates to the left and to the right side. and thats those jumbles of resistors.
Is that a sound deduction?
So two points:
1. I have a little issue with seeing certain colours , so decoding the values thereby deducing which resistor is which is hard
2. As I can't deduce which resistor is which i have a hard time applying the schematic to reality to understand how its all connected the way it is in reality.
From each terminal of the reservoir cap goes a wire to a point which is connected to another terminal with a resistor. This point is also connected witha resistor the the terminal point of the other polarity.
So from each point with a cable leading to the underside of the pre amp (one per side) each point is connected to both polarities of the reservior cap
...just with two different kinds resistors.Unsoldering them, they are off their spec (if I assume they are the resistors i belive they are , circled in yellow)
But not in such a way to cause 26 volt to become 54..
I have studied these posts, ven though my issues are slightly different
/forum/imported-unmapped/beomaster-3000-type-2402---blows-fuses
But Can't realy find deviations in the Ohms.
Thanks.
