Hello all, and thanks a lot for this wonderfull forum.
I have a problem with a very shy Beosystem 2500 I bought : although I can hear the tape, the CD and the radio through earphones, the volume is so low, as if the beosystem is whispering. I can hardly hear the music.
I followed the advice I found on the forum to press sound-0-store or sound-1-store, the indicatior led flashes but nothing else happens.
Using the remote control, or the panel buttons, can't make the volume change. Also I have no indication on the display that the volume is changing, and the mute botton does nothing at all.
I bought the beosystem from Ebay, and the seller says that it was working. I don't know if anything happened during it's courier trip from UK to Greece, but it arrived to me in good condition.
Any help or guidance will be highly aprreciated. Thanks in advance.
