Hi guys,
my cd's jump around on the spindle initially before settling down or failing jut opening the door again.
It does seem to be a physical issue rather than electronics but i can't find a way to adjust the clamp that helps. I tried bending it ever so slightly to exert more downwards pressure but it is unpredictable and actually stops the disc sometimes instead.
IN the video you will see it works fine with gentle pressure from my finger on the clamp but jumps about without it.
video link;
should there be some sort of "grip" on the spindle holding he cd in place effectively ? if so its missing
Dan
