Could anybody help with the following,can a 9500 turntable be used with the 6500 system,
Regards Members
Regards Members
Not directly - the 9500 does not have a built in RIAA which is needed for the 6500 system. You can get an external one but there are also issues with the remote control - easier to get a deck with the RIAA already in. 6500, 7000 or 4500 are the common ones.
Doesn't the 9500 also have the 2 extra data pins which need to be removed from the phono cable?
Dave.
