chris_in_cal wrote:
I've seen other discussions here about "Good HiFi" replacement foam for these Penta MKIIIs.
How much would be accomplished of the restoration if these are refoamed, and the amps are freshened with Dillen's service kit? What else typically needs to be repaired or replaced in these speakers to have them back to making beautiful music?
Hi Chris
If the drivers are still intact, I wouldn't refoam them. My MK IIIs still show no sign of foam rot, It all depends on the environment they have been subjected to.
The two big 10000uF electrolytic caps in the power supply (not in the replacement kit) will eventually fail, and I would recommend replacing them asap.
The choice you make here is where thing turn into rocket science,- the price range is 10-75$ a piece, Perhaps Dillen has a good suggestion?
As long as you stay away from EBAY parts (Use Mouser or Digikey) you should be fine.
If you have no equipment available I would recommend leaving the R95 trimmer alone.
A hint: When you start swapping components do it in small groups and then do a test, It makes it a lot easier to isolate an issue if you can narrow it down to a few parts to begin with.
Make sure you have a PAPER copy of the schematic where you can make notes and markups, I cannot stress this enough!
The PCB material is FR2 Phenolic paper and the peel strength is close to zero, always extract pins from the component side AWAY from the board.
... And be careful you are dealing with 150V across the supply rails. With the 10000uF caps there is 110j of energy stored.
If in doubt,- its always better to ask another question than wreck the whole thing beyond repair.
