Zektor and BeoSystem 1
I got it!! Thanks for all of your help. It turns out I didn't go into the Beosystem 1 menu and select component for all of the sources. Now I just have to figure out how to set the wii to 480p without any video on the BV 4 (It is automatically set to 480i in the wii).
Thanks!!!
Thanks beobuff for the detailed explanation of the Zektor's input and the specific fixed order in which they are set.  I have been search B&O forums ever since I got a hold of my Zektor H4.1 tried to get it to function properly w the BS1.
 Final tonight everything is running smoothly.  It's amazing when everything just comes together.
Thanks to diggs2701 for initiating the thread as well.
 Conjureone
This is horrible news.  Rolland has been an invaluable source of assistance to me over the years.  His departure from BOA is tragic.
If Rolland reads this message....thank you for all the help you have provided me and good luck with whatever new endeavors you pursue.  You will be missed.
This is indeed very bad news for B&O customers. Rolland had always gone the extra mile to help me and was able to handle even the most complex technical issues. In many cases, I found that other technicians would give incorrect information and answers. However, Rolland's technical advise was always sound. He will be missed.
