Zektor and BeoSystem 1
What versions of the Zektor Component Switch (HDS4, 4.1, 4.2) works with the BS1? Thanks in advance.
 Diggs2701
The HDS4 has a default IR code that is ready for the BS1 PUC. Therefore, there is no programming needed.
However, the HDS4.1 and HDS4.2 can easily be programmed to work with the BS1. Also, the HDS4.1 and HDS4.2 have buttons so that you can manually switch the input. This can be very useful in some circumstances. For example, if you have a dvd player connected to the BS1 via s-video, you then have an unused dvd input on the Zektor box to connect a component device.  Then, if you hit, for example, "V.AUX" on the Beo4 and quickly press the button for the dvd input on the Zektor box, you can utilize that extra component input. This can all be programmed into the Beo5 with a macro to automate this if you also have a lintronic device.
I just bought the HDS4, when I hook up do I need to put the IR sensor in front of the zektor in order to use with the Beo4? I am trying to hook up my Comcast Motorola DVR, DVD Player, Wii and Apple iPod dock to all inputs of the zektor switch. Thanks!
Yes, you need to use the IR transmitter on the Zektor switch. I did the same, and have the HDTivo, Wii, and AppleTV hooked up through it.
How does the Beo4 know what component is on what channel of the zektor switch?
Are there certain ways that I should be hooking up each component? Do I need to assign the component (DVD, CABLE, WII, AppleDOCK) in the beo4?
Thanks!
I haven't used my BS1 or Zektor switch in over a year, so this info is all from my increasingly dim memory of how it all functions. I hope I still have it all straight.
The Zektor switch should be used only for the three component video leads from each video source; the audio and IR connections from each source should be connected to and switched directly by the Beosystem 1 as per usual.
The component video leads from each source have to be connected to the Zektor inputs in a specific fixed order: (1) STB, (2) SAT, (3) VAUX, (4) DVD. Only then will the Beo4 buttons activate the desired source. Note, however, that the order of the inputs on the back of the Zektor (left to right) is the reverse of the order of the connectors on the rear of the Beosystem 1 (right to left).
The IR flasher for the Zektor should be connected to the VAUX IR output socket on the BS1. If you have a video source connected to the VAUX sockets on the BS1 that also requires operation with an IR flasher, then you must use a Y-connector to split the IR socket output to the two flashers. Not to worry, the Zektor IR codes won't interfere with the VAUX source's codes and vice versa.
Lastly, be certain that your Beosystem 1 has a recent software version installed that lists the Zektor switch in the setup menu - it is the last line item in the menu and has only off and on as options, as I recall. If it is not there, you will have to get the BS1 software upgraded in order for the Zektor switch to function with your system.
I hooked it up and the Motorola Comcast DVR works great in slot 1 (STB) but the remote for the motorola box switches the input on the zektor box (I think it interferes, same codes)
I have my Wii hooked up to the (2) STB using Monster Cable Component Cables but I don't get any video
I have a iPod hooked up to (3) VAUX using apple component cable but I don't get video, just audio
DVD player hooked up to (4) DVD using component cables and everything works fine
Any help or ideas would be appreciated! It has been a long process! Thanks!
I recall B&O tech support advising me that certain motorola devices use the same code as certain Zektor boxes, which results in interference. You should ask for Roland in U.S. tech support to see if he can help with a solution.
My zektor switch is working fine, I am just wondering if anyone else hooked up there wii/iPod/AppleTV to the switch to a BS1. I am sure it is an easy fix but for some reason I am not getting any video from the Wii and iPod (maybe there is am adjustment I have to make).
beojeff,
Thank you, I will call support to see if there is anything I can do about the interference. It turns out, if I close the door for the level the switch is on in the cabinet it doesn't do it.
Thanks.
