Hi guys,
i need your help
mostly I want to get your opinion about these three products I want to buy for cd listening purposes.
Yours truly
Bang & Olufsen Neolab 4500 (typ6721) vs Geosound 3000 (typ 2671) vs Beosound Ouverture typ(2631)
Hi guys,
i need your help
Yours truly
Beolab 4500 is an active speaker so you need to have a source connected, like any of the two Beosounds you mention.I personally owned a Beosound 3000 and was very happy with it. Classic design and masterlink capable if you would like to expand your system to other rooms. Make sure all mechanics work when you buy.Hi guys, i need your help mostly I want to get your opinion about these three products I want to buy for cd listening purposes. Yours truly Bang & Olufsen Neolab 4500 (typ6721) vs Geosound 3000 (typ 2671) vs Beosound Ouverture typ(2631)
Dear Hiort
Thank you very much
İs it possible (to play with) or is it good with Beovox S45 speakers for Beosound 3000
Thank you.
Dear Hiort
Thank you very much gör your Help Now i will try to find öne of that.
best regards
