Couldn't find any difference but the interfaces (SPDIF). Sound-wise any improvement?
Worth to upgrade from Essence MKII to Core?
Had them both. i found the essence MKII annoying it kept popping in the middle of the night. Swapped it for a core, same speakers no difference in sound thoughCouldn't find any difference but the interfaces (SPDIF). Sound-wise any improvement?
This issue luckily I don’t have. So I save the money for the core.
BTW: If you pair the Essence wheel remote with the Core, is there the same horrible lag if you use it first time?
Yes, it happens frequentlyBTW: If you pair the Essence wheel remote with the Core, is there the same horrible lag if you use it first time?
Sooo annoying - appears so cheap. When visitors using it and are confused why it’s not immediately changing volume I always get a “nice” comment abou my pricey hifi equipment :))
I guess it is because of the power saving mode of the Bluetooth connection. If you don’t use the remote a while, obviously the Bluetooth connection first needs to get re-established which takes time.
Yes I had that last week happens very rarely though but what I have found is that by checking the BeoTool the essences need to be software updated after this is performed the popping sound disappeared😉Had them both. i found the essence MKII annoying it kept popping in the middle of the night. Swapped it for a core, same speakers no difference in sound though Moving on to an integrated smart home killed the doorbell.
It seems you are all lucky, I have 2 remotes, one on the countertop kitchen and one on the kitchen table. Every 2 weeks they just loose connection. ..Sooo annoying - appears so cheap. When visitors using it and are confused why it’s not immediately changing volume I always get a “nice” comment abou my pricey hifi equipment :)) I guess it is because of the power saving mode of the Bluetooth connection. If you don’t use the remote a while, obviously the Bluetooth connection first needs to get re-established which takes time.
I installed a core and essence remote a couple of months ago. Initially I had quite frequent lags where using the remote took up to ten seconds to work. Having moved the core a little closer and so that it is less “hidden” by furniture I have eliminated such delays.I have never had a completely lost connection. So it would appear that position/location and proximity is important. Although clearly moving the core or the remote may not be an option for some.It seems you are all lucky, I have 2 remotes, one on the countertop kitchen and one on the kitchen table. Every 2 weeks they just loose connection. .. Moving on to an integrated smart home killed the doorbell.
