Wisa usb transmitter
Anyone use a wisa usb transmitter with lg oled?
I orderd a lg oled c9 77 and thinking of use wisa to my speakers. Beolab 10 with beolab reciver and beolab 50 as fronts and 17 as rears.
Was to cheap to pass.
I would recommend the axxim link wisa. Is magnetic and can just stick on the back of the screen, goes up to 7.1 and you have individual control over all the speakers and can up and down mix if needed.
Also 50’s won’t have their active room comp in wisa, just be aware of that and won’t do 24bit 192khz anymore, 24bit 96khz max. I wouldn’t advise it for 50’s or 90’s, but you can do it, just wired is better.
Mikipidia wrote:
I
This is not entirely true. It is more correct to say that only a portion of the ARC is functioning when using a WiSA connection to a pair of BeoLab 50s or 90s. This is because, in order for ARC to work at its maximum potential, each loudspeaker has to receive both audio channels. Since the WiSA receivers are one-channel only, then the ARC is not getting all of the information about the incoming signal that it needs to do a complete job.
However, I would say that it's doing more than half the job, depending on the coherence of the two audio channels. If you only listen to monophonic music, then you will not notice a difference at all. If you only listen to recordings done in very large reverberant spaces that were captured using a Blumlein  or a very widely spaced omni mic technique, then your ARC will be running at something like 50% - 70% (although using percentages for something like this doesn't really make any sense at all...)
Cheers
-geoff
PLEASE READ before sending me a Personal Message. If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department. I cannot be a "short circuit", bypassing these communication channels. Thanks -geoff
I don’t use room compensation. I have the mic but they are good enough in my room and cd quality is all my ears need. Just want to know if it works. Otherwise I need the harmony. Not sure I wont to spend the mony.
I wish b&o did a beolab transmitter with usb or hdmi. Or stage with wisa. And I belive it’s coming.
Cheers -geoff
That's what I suspected.
Tune them either way with the mic if you haven’t yet, if you don’t like it you can always not use it😎
I’ve heard of people for instance using the axiim link with lg c9 and bl18’s/17’s/7.2 and 19 with great succes, I heard the system and seen the adjustability of it. That’s why i would recommend that one over the LG wisa stick, my dealer also sells them (axiim) as they work so well with each other.
I’d like to here from people first hand.
I just checked with a couple of people here about this question, since I was a little concerned about it...
This system will unfortunately not work as a surround configuration due to latency mismatches. The BeoLab 50's have (in Low Latency mode) a 25 ms delay, whereas the BeoLab 17's have a 4.4 ms delay, and the Receiver + BeoLab 10 has a <1 ms delay. This is on top of the WiSA latency, which will be the same for all three device types (the BL50's, BL17's and the Receiver).
This means that, in cases where you have the same signals on the L/R front and centre (or surround) then the BeoLab 50's will sound like an echo.
You could "fake" the latency compensation with a delay control - but this is currently not available in the LG television's menus (which is where it would have to be), as far as I know.
Cheers
-Geoff
Thank you for taking the time to answer my question.
I am aware of the delay. But you can set a distance in the B&O app for beolab 50. Does it work with wisa? And axiim link has an app that I hope you can set the distance to. How much I do not know yet. Shouldn't that work?
In low latency mode, the BeoLab 50's have a throughput delay of 25 ms. This is equivalent to a distance of 8.6 m. So, all of your other loudspeakers will have to wait for the BeoLab 50's.
Setting the distance in the 50's will only account for the differences in distance between the two of them, and this can only make one of them later (the other will be set to a 0 ms offset). So, this will not work.
I have never used the Axiim, so I don't know whether you can add the required delay to the 3 other loudspeakers to time-align to the 50's. Once you get it, I'd be curious to know whether it does.
As far as I know, the TV does not have a speaker distance adjustment in its menus - although this might have changed in a SW update since the last time I checked, so again, I'm curious to know, once you get it.
Assuming that you CAN enter a distance adjustment in either the TV or the WiSA transmitter, then
