WISA A9 - Avant 55
Would this work????
new A9
two receiver 1 plugged into line-in of A9 (LR)
USB to RJ45 power cable for receiver 1's
Avant connect by WISA to Receiver 1's
They fit into the rear panel of the A9 neatly.
I think it will just not sure if the 5v from the A9 USB out will run the receivers via RJ45???
Would welcome some expert advice
It's for music in the kitchen and is line of sight comfortably
Mike
Just link the two devices.
Both the A9 (new) and the Avant are NL capable - and can be part of a BeoLink multiroom setup.
The solution will work, but MM is right, if you aren't going to try to use the A9 as rear channels or the like you should simply BeoLink them together and use the join function etc.
