Wireless music streamer with a Powerlink socket
Hi Beoworlders,
Just a quick question - I have found a good quality wireless (wi-fi and bluetooth) music streamer with a Powerlink socket for direct connection to Beolab speakers - would any of the group members be interested if I made a video to explain how it works?
You can see details of the streamer here:
Video would be great !
Thanks!
I will start working on the video this week - it will be uploaded at
That's very cool, but I have to ask, even though it has a DIN out, does it have the trigger signals needed to turn on a pair of Beolabs or is it just the audio signals?
Hi Jeff,
Yes, this is a proper Powerlink socket - the first thing I did was to plug in my Beolab 3000s and Penta 3s when I got the streamer - they came straight to life when the music started to play so the trigger signals are present and correct!
There are also 3.5mm minijack inputs and outputs as well (volume controlled via the app, or from the buttons on the top of the streamer).
Kind regards, Steve.
Very cool. I actually have a use for such a beast.
Hi Jeff,
I have 7 of them here at the moment, if you want to try one. (
Just ordered one Steve, thanks! Hopefully this will solve a short term problem I have, my Beolink Wireless 1's have totally crapped out and I have no music in the dining/sunroom/kitchen area. I plan on hooking this up to my BL8000s. Eventually I have a BM2400 I'm restoring that might well live in here but a device that talks powerlink will be good to have.
Thanks Jeff,
This will be in the post to you in the morning with instructions included.  Please let me know what you think when it arrives!
It should also work with the BM2400 once you have that ready, as it can connect via the Tape input.
BTW, I dug out my old Playmaker, and sitting here 10 feet from the wireless router it took almost half an hour to get it to connect to the network, and it stuttered and dropped out constantly. What a POS, and it's even too light to work as a decent door stop.
Look forward to the TIBO, and will let y'all know how it works. Finding a product that talks B&O is not easy, good find.
