I hope the screens end up in the Oled b and O!
Read more here.
http://www.insideci.co.uk/news/lg-reveals-oled-and-nano-cell-super-uhd-tv-strategy.aspx
Read more here.
The new tv's are rumoured (!) to be based on the E series from LG.
Out of interest Is that another previous gen screen?
If the E7 are going to be used....
AVSforum just mentioned prizing and release of the LG originals (in the US):
55″ E7, $4500, May
65″ E7, $6000, March
The won't come cheap, then.
If this years E6 will be used, they might come a bit cheaper, of course.
As for when? It would be odd, if the wait untill this fall with the release ----- and still use the 2016 models, wouldn't it?
But don't forget - there is nothing confirmed yet!!!
On a sidenote:
No matter which series or even technology, they will be using for the LG/B&O tv's, it will be an upgrade to the current.
The bigger (much bigger) question is, how do they integrate with, what is core B&O?
How will the sound/sound engine work with/in these modern picture-focussed tv's?
How will the interface be - how well will they work with current NL (and also ML) products.....?
Ohhh - and how stable will they be?
add in the B&O audio processing, and presumably design added value, and i dont see any reason to believe the TVs will be priced any cheaper than the existing range.....i.e a current 55inch, whether Avant or BV14, is roughly 7000-8000 (GBP), i'd expect the OLEDs to be similar.....
as MM mentions, would be hard to consider the E series as out of date tech......whether they use last years or this years will get people very agitated, though by all initial accounts there isn't a huge difference between the e6 and e7 panel, albeit the e7 hasn't really been reviewed yet........
So, no Oled panels in the current BV14 or Avant then? I hear these pronunciations more often.
