... or is there a weak link somewhere?
Laptop (w uncompressed music) >> WiFi >> Airport Express >> optic digital signal >> Optic/Coax Converter >> digital signal >>
>> BL5 w internal DAC >> digital signal >> BL5 w internal DAC
As I understand things the entire chain from computer to BL5 must ensure perfect bit-to-bit transfer (since it would otherwise be impossible to use WiFi etc for transfer of data files, programs etc). Therefore the digital signal that reaches the BL5s must be an exact copy of the
uncompressed music file stored on the laptop. This means, if I am correct, that a high end CD-player will not improve anything, and since
we are using the internal DACs of the BL5s there is no need for any other high end DACs.
Is there any fault in this reasoning - because if not - any loss of quality will occur in the BL5s, for example poor quality of the built-in DACs. However, I suppose these are of very high quality - and therefore - this system (very inexpensive up to the BL5s) will be "absolutely high end" :-)
/Munin
