Will a BV14 Panel fit BV11
As title,
Does anyone know if the new BV14 Wooden front panel will fit the BV11? It looks very like it would?
It would match the BeoLab 18's really nicely. :)
Yes, someone in the know has confirmed that it will fit similar sized BV11 sets. I'm assuming with the most current chassis (magnets).
Excellent, Has anyone seen the BV14 with the wooden font next to the 18's? How do they look?
Over the weekend I noticed a Danish B&O store selling the BV11 version of the BV14 fret, online. Not sure if it was a pre-order (it was all in Danish), but it's promising.
I'm certainly intending to get one of these wooden BV14-40 frets for my BV11-40.
According to my dealer the wooden cover can be used on the 40/55 BL11 - actually it was intended so from B&O.
I did not hear anything about two different versions.
In the flesh they look superb - very well crafted.
The lamellas are not uniform (like those on the BL18) - they are differently shaped, which makes the surface look quite nice.
As an addition to the 'wooden BL18's' it looks perfect...
....if you like wood ;-)
But the BV11 has two variations of fret? It has the old magnets and newer clip-on fret? When I've ordered new BV11 frets in the past, I get asked "do you have the magnet or clip-on BV11 model?".
So, if you have a magnet-based BV11, then I guess you can't use the BV14 wooden fret.
Moxxey, the BV14 wooden frets, do indeed, use the magnets, they are compatible with the newer BV11 chassis (which uses magnets, not clips).
Discrimination of the bv11-46 inch owners
Yes. A little unfortunate.
