Wii & BV5
I have a first generation BV5 which is great but have just bought a Wii and am a little worried about 'screen burn in' from stationary images/patterns (the Wii has a screen burn-in reduction feature).  Can anyone here help me with this? is it something to worry about? or is it only when being used for long periods of time e.g. several hours of play?
 Thanks in advance, Hughie
I personally wouldn't be too worried. So long as you're vigilant and don't, say,  leave the Wii switched on at a menu screen for a long time, it shouldn't be a problem. Probably best to turn on the Wii's screen burn-in reducton feature. It really needs a stationary image for a long time to suffer screen burn in (eg channel logos).
 Yes screen burn in is a problem with earlier plasmas, but if you're careful you should be ok. You could always get a small (26in?) LCD for playing the Wii, if you get concerned about your BV 5 suffering burn in. I'm planning on getting a BV 8 which will have my Wii connected, and as far as I know, LCD's dont suffer burn in, so that may be a better option.
Robert.
hello robert
thanks for the reply, its pretty much what i had heard already, have activated the wii safety burn-in feature and the kids are loving it already
 cheers, hughie
don't forget to use component cables if at all possible , that sharpens up the wii's picture quite a bit and improves the colour handling
maybe add a ps3 while you're at it - your kids would love rachet and clank , believe me ! :) it'll also look staggering on a superb tv like th 5
So long as the kids know not to leave the Wii turned on and the BV 5 turned on, you'll be ok. Great console isn't it, I have so much fun playing it. My brothers both have XBOX 360's, which are also very good, but I prefer my Wii.
Enjoy your Wii/BV 5 combo,
Robert.
