I have four Beolit15s. I use them equally with Bluetooth and with streaming audio. I have tried for over a year to get a quality audio streaming signal into the 3.5 mm port from an Apple airport express and failed. I have purchased two Chromecast audio dongles and have had absolutely excellent results with both. Neither of the Chromecast devices will work with Airplay but I have found that I can find other streaming services that will compete with Apple’s Apple Music. Does anyone know why this is? Is the digital to audio converter so much worse in the Apple product? I really like Apple products but the sound difference is quite striking; the fidelity is quite poor and in particular the upper registers come off as dull and very flat. I would appreciate any insight as to the technical reasons, if there are any, for why this is the case.
Why does a Chromecast audio sound so much better when streaming to Beolit 15 than an Apple Airport Express second generation?
Indeed there are different views on the sq of the APE .
have a look here:
Or just read what Ken sums up:
’At any price, the Apple AirPort Express is a great DAC. It sounds great, with a completely silent background, full 2 V output, smooth detailed sound and full infrasonic bass response.
For best results, leave your player's volume at its maximum for maximum output from the AirPort Express, and then vary the playback level with your Hi-Fi's volume control.‘
Also Archimago did some measuments/testing with the Chromecast Audio.
Here is the first part:
Feel free to read....and to test on your own.
MMlink
I found that you can get excellent results with an AE if you feed the output to a DAC - the audio out also serves as a SPDIF (optical digital) output and you can feed that into a DAC and then into your audio system. It is very very good dependant on the DAC you are using. The built in AE Dac is poor,.
