Why are N.Radio stations different on Beousound 5 and the Avant55?
I am getting a Beosound 5 up and running. Besides the obvious issue with a slow process for searching stations, one major station that is on my Avant 55 doesn't come up on the Beosound 5. I have the maximum buffer set, and cleared databases and reloaded on the BS5.
Is there any way to get a searchable list of all radio stations currently on N.Radio?
What URL does the Beosound 5 go out and touch to get the N.Radio list?
Thanks,
Gregg
Hi Gregg
I had earlier requested B&O to add missing radio stations to BS5 by sending them a request.
I suggest that you do the same a refer to specific radio channel on Avant so they can find the correct URL for radio streaming.
Leo
Oh. Remember to add the stations to your favourite list so you just have to enter Radio and a number from the favourite list 😕
Thanks. Turns out I found the station under the name “classical kusc”. I found a trick for cutting searches shorter. Once you have favorites set, if you start playing a station then search it will start with that station’s name. By picking stations with starting letters around the alphabet you can save time.
