Greg:
Thanks guys. I think I already made the decision ;-)Finally, one really simple basic question I should probably know the answer to, but don't. If you're watching a DVD which has say dts surround audio, and of course you want to experience that surround on your beolabs via the surround module, how to do connect the DVD player - i.e. how does the surround/multichannel information get communicated from the DVD to the surround module in the TV? If it's connected via DVI (for picture) and red/white phono plugs (for audio) then surely the TV only receives stereo audio, not 5.1? So is that information communicated instead via pins on the SCART connector, so I would connect the DVD via SCART??
You simply have to connect a coax cable that will feed the BeoVision with your DVD 5.1 channel (providing your DVD player has a coax output, otherwise you'll have to buy an optical to coax adaptor). And then just tell the BeoVision which AV scart is coupled to this surround signal and that's it...
Really straightforward.
Philippe
