Who has a BeoCenter 6-26?
Well, I went into the dealer to take a look at the BV8. Initially, I didn't like this TV at all when I saw the pictures. The 'shelf' is interesting, though, and the look of it is totally different to anything else, which appealed to me. So, I go in and have a look. Firstly, it looks every bit as unusual in reality as in the pictures, and a little nicer. The huge B&O logo which had really put me off actually doesn't look so bad - in fact it's very subtle in the flesh. And the Serene-type soft-touch plastics are pretty high quality. And most of all, the sound really is very impressive indeed.
But... they had it set up right next to a BeoCenter 6-26 and - to put it mildly - there's absolutely no contest in terms of quality - both quality of manufacture and picture quality. Now obviously the BC6 is dearer (GBP 3,000 versus GBP 2,000), but to me it looked worth every bit of the difference - and then some. Much more B&O, with proper glass screen, and very high build quality.
I'd never really considered the BC6, because I thought I needed a 32" screen size (I'd gone to see the BV8 in anticipation of the forthcoming 32). I always liked the look of the BV6 in preference to the BV7-32 (which of course is bundled with a very average - and expensive -DVD player that I don't need).  And sitting in the dealership looking at the 26" across the room it seemed perfectly big enough.
Our living room area is pretty small (about 5m x 4m) and so in any case having a smaller TV would be nice in the sense of not totally dominating the room. However, I do like to watch a movie occasionally and would strongly consider getting the surround module (in place of the DAB module that I wouldn't use) and - ideally - 4 x BL3s on floor stands, or 4 x BL4000s if money's tight!!
So here's where I need some help. Does anyone have a BC6-26 as their main TV? Is it large enough to watch movies on occasionally? And are you happy with it in general?  I'd really love to get your views about this TV.
Hey Greg, I've had my BV-22 for about 2 1/2 years now and I have to say its been superb. My old living room size was about the same as yours (4.5m x 4.5m) and I found my reduced size screen perfectly adequate for my viewing needs.
Superb features like the anti-reflect and auto adjust make the set a delight to use; its just I don't always appreciate it until I view a friends Sony!
/A
Hi Greg,
I'm in the same configuration : my living-room is 5m x 4m, with a distance TV to sofa of approx. 2.5 m.
I have a BV6-26 (with the surround module, BL3, BL2 and BL6000) and must say I'm extremely pleased with it. The TV doesn't eat space, the picture size is perfect, as well as the surround set-up. I have the BV6 on the motorized floor stand and I can only praise for its integration, and picture/sound/design quality.
Philippe
I think the BC6-26 would be the perfect choice for you(and IMO it looks gorgeous!), but you have to be aware of the viewing distance.  If it is superiour to 3m, a 26" could be a little small...
Thanks guys. I think I already made the decision ;-)
I'd also looked at the Sony bravia w2000 32", which has 1080 (full HD) resolution but its picture wasn't as good, strangely. And of course is a much cheaper, very plastic-looking TV.
But some more questions!
I guess the BC6-26 will support HD at 720p?  I don't yet have Sky HD (but probably will do), is it OK for this via its DVI input??  Do you guys have HD sources connected?  I must admit the one thing that still puts me off this set is the lack of HDMI or component video connection - seems like it's outdated even before I buy it.
I'll want to connect Sky HD box (and control via Beo4/5), Apple TV or similar (and control via Beo4/5), DVD player, and Wii. Ideally, I'd like to connect each one via HDMI or component, and on the BC6 I'll only have one DVI connector.
Finally, one really simple basic question I should probably know the answer to, but don't.  If you're watching a DVD which has say dts surround audio, and of course you want to experience that surround on your beolabs via the surround module, how to do connect the DVD player - i.e. how does the surround/multichannel information get communicated from the DVD to the surround module in the TV?  If it's connected via DVI (for picture) and red/white phono plugs (for audio) then surely the TV only receives stereo audio, not 5.1?  So is that information communicated instead via pins on the SCART connector, so I would connect the DVD via SCART??
Sorry for all the questions and thanks for your help!!!
Update - I just went and measured and it's about 2.5m from sofa to the low unit I plan to put the TV on.
So I'm thinking the 26 is big enough!
G.
Since the BC6 has video out conections I would think you could add a projector if you feel the picture is too small. That would be my personal preference. Small B&O TV for surround and casual TV watching, projector for movie night.
JK
Hi Greg,
we had a BV6-26 when it came on the market. The viewing distance was nearly 3m. Picture and sound (with surround) were really great. Due to some rearangement of our living room the viewing distance changed to 5,5m so we needed to upgrade. But the look of the BV6 was better IMHO as it has not dominated the room that much. Go for it!
Marcus
hi Greg,,I don't have BeoCenter 6-26 ( in fact I have never seen one in North America)!!, but I have 2  LCD  TV.In
one room- the bedroom - ( which is 5x4 m) I have a 19' LCD and in the livingroom (6x5m)  a 26' LCD. In fact I don't like to have big screen TV, which is by the way 'a la mode'   ,  and the 26' is more than sufficient for my needs ( a big screen would dominate the room also). On the other hand, if you are a movie watcher, I would go for 32-40' because it's a little bit annoying looking at a 26'!!!! Me, I'm looking only at documentaries movies ( PBS, National Geographic etc..------In fact I prefer not seeing a LION or DINOSAUR on a 65' screen  ___in my house I'm the king - I'm the big one).........
In your case, I would buy a Sony ( 26' for ex.) and see if I'm happy with it. If the size are acceptable ( 1-2 weeks are more than sufficient to arrive at a decision about the screen size) I would return the Sony and go for B&O once the decision is taken ( 26 or 32)....
regards,
constantin
You simply have to connect a coax cable that will feed the BeoVision with your DVD 5.1 channel (providing your DVD player has a coax output, otherwise you'll have to buy an optical to coax adaptor). And then just tell the BeoVision which AV scart is coupled to this surround signal and that's it...
Really straightforward.
Philippe
