Which TV should I be buying - Advice needed
Hi All,
I have a Beovision 3 32" in my bedroom and would now like to use Apple TV etc and so am thinking about upgrading. I also have a Beosound 9000 and Beolab 9's connected to it, so this probably needs to be taken into consideration.
I'm after a TV with a picture better than my current. I was looking at either a Beovision 7 40 Mrk3/4 but also came across the Beoplay V1 and wondered what the general consensus is?
Is the Beoplay V1 any good or is it just a very entry level product? I know it doesn't have master link and this probably poses a problem when wanting to connect it to my equipment? Also, how does it compare to the Beovision 7 40" Mk3?
I apologise in advance for asking so many questions but any advice received would be appreciated.
The picture will be much better than the 7-40 mk3.
It also includes Beosystem 4 I believe so quite a package, except cosmetically. Even though I loathe its looks, I'd buy one over a Mk3 7.
A Mk5/6 would be a different matter.
Hi Chris,
Thanks for the response. The question then becomes how would i connect the TV to the Beosound 9000?
check out my signature....
only thing I miss is Beo 4 control of all the equipment - which could be done with lintronic devices.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
londonguy wrote:
Hi all,
I'm now now considering doing the inconceivable, I would never uttered these words years ago but can't find an alternate solution which seems worthy.
i came across a samsung f8000 46" TV and found the picture to be truly stunning, I compared it to the V1 and it blows the V1 away, therefore I've decided not to purchase the V1. Also, I don't think a second life beovision 7 mk3/4 would fare much better. The only problem is I have a beosound 9000, beolab 9000's and a beolab 2. If I bought the Samsung (dreaded thought), how would I connect it to the equipment?
Has anyone else moved away from B&O screens and lived a fulfilled life? Lol
How were you able to do that comparison....side-by-side?  And what do you mean by "blows it away"?
The comparison wasn't side by side but the picture on the Samsung was clearly sharper, more detailed and a lot more vibrant. I
Which source was displayed?
Compare them in store. I have never found the V1 picture anything other than nice or ordinary. I don't want it to be so, but find myself buying up Beovision 8's to fill the gap.
Well I have just done the opposite!!
Started out looking at cheaper alternatives to replace BV26-26, spent months looking around, and yesterday ordered a V1-32.
Have decided not to integrate it into my ML network but that in due course will get a matrix.
Mike
Is it easy to integrate the samsung with Murphy current setup with out having to buy a separate receiver?
