Which subwoofer to pair with Beolab 3s
Hi. I recently set up a pair of 8" powered studio monitors in my bedroom, and I found myself noticing the Beolab 3s in the living room really are four inch speakers. Spooky 4" speakers, but 4" speakers. They're connected to a Playmaker.
I picked up a Beo 4 remote to adjust bass and treble - thanks for that tip! - and that's helped a fair bit, but I find myself thinking "proper subwoofer?"
Choice seem to be Beolab 2 or Beolab 11. https://www.youtube.com/watch?v=erKm7sqg2zg this chap seems to be of the opinion that the Beolab 2 isn't great for music (my primary application) and the 11 is The Business, but also points out that the 3s are already pretty solid and the 11 doesn't add much.
So do I want a Beolab 2? Do I want a Beolab 11? They both seem to do bass filtering, so I can plug the Beolab 3s directly into the sub and let it sort out who plays what... and I'm guessing on aesthetics alone the 2 and the 3s play nicely together, they were clearly designed as a set.
Your expertise is greatly appreciated. What should I buy? Are there other options I should be considering?
I have 4 Beolabs in a surround set up combined with a Beovision Horizon and a Beolab 11. Beolab 11 does not deliver the 'deepest' punch when watching a film (although it is undoubtedly there). On the other hand, the Beolab 11 certainly gives that extra - but wel balanced - bass when listening to music without exaggerating. The addition of the Beolab 11 is well noticeable (I have programmed speaker groups with and without the Beolab 11 in my set up and I absolutely prefer the one with Beolab 11). The Beolab 2 would certainly be better for watching movies but if it would integrate as nicely with music???
For the sake of completeness, I noticed that I forgot the '3' in the first sentence. So 'I have 4 Beolabs 3.......'πŸ™‚
Having the same setup in combination with BV10 and BS5 and must say that I don't miss at all a stronger or deeper punch than the BL11 is delivering. Neither for movies, nor for music. But I had to adjust according to the room conditions to get the most out of it....
BL2
This is exactly what the BL11 was designed for. Adding bass for music, not a true subwoofer for movies.
BL2, movies best, music bit slow
BL11, music and subtle, movies not useful
BL14/S8 sub, both music and movies
BL19 both music and movies
This is how I would rate them
I use BL11 to add a bit of β€œbottom” to my BL3s.
Very happy with the results.
Sounds very balanced together.
And it’s awesome it can be mounted on the wall πŸ™‚
So it sounds like a strong consensus that the Beolab 11 works really well for music and does add something with the Beolab 3s.
Anybody using the BL2 for music? Is the reported "slowness" really an issue?
Has anybody tried it and found it to be a problem? How does it actually show up?
I used a BL2 with a music-only system paired with BL8000s, and then I upgraded to BL1s.  I think it's great.  I don't understand why it gets such poor reviews on this site.  Perhaps it's the difference between our large "stick and cardboard" homes here in the US vs. European small and solid construction.
As I mentioned in another recent thread on this topic, there is some music that seems to resonate the passive drivers too much causing some muddiness.  This was demonstrated to me with a Massive Attack song.  This really isn't a genre of music I listen to so I have had absolutely no problems the music I listen to - Alternative Rock, Classic Rock, Classical, Jazz, Punk, New Wave.  You may need to experiment a bit with placement and switch settings to get the best sound, but, for me, it delivers everything its supposed to and really improved the sound of the 8000s and subtly improves the sound of the BL1s.
