Which MINI PC for TV
I'm using an Odroid N2 with coreelec installed. This basically is a mini pc with a 'linux' operating system that integrates the latest kodi build. It's perfect for playing local content, very customizable. It does all uncompressed 4K formats and hd audio and can be operated through hdmi-CEC. It's quite cheap too. I was using an older macbook before which only purpose was playing local content. After finally ditching my old 720p TV, it seemed the mac could not handle uncompressed FullHD video smoothly (2008 hardware) so I needed to upgrade. Was first looking at a secondhand mac mini, but that could also not handle decent 4K content and was way more expensive than the €100 of the odroid (or even less, can't remember).
It depends on what you're planning to do with it. I'm not a big fan of streaming, playing content on my laptop and mirroring its screen does not deliver a smooth enough experience. I hate to use separate remotes too, and controlling play/pause on the laptop while watching series is really not ideal.
I guess netflix and other streaming services are built into the LG you're buying, so you're mainly looking to playback local content?
An Amazon Fire TV Stick with Kodi can be used to access network drives.
We use this solution to watch centrally stored movies.
Even a wireless keyboard including mouse pad works with it (if you go for the fire hd box, not the stick).
Ralf
or Nvidia Shield TV if you need something faster... for KODI etc.
Forgot to mention: With a FLIRC USB adaptor it can be controlled via Beovision PUC system (for example Apple TV PUC) as the FLIRC adapter can be programmed for various commands with a computer.
Check this thread (and linked ones) also:
Ralf
I'm using a FireTV (the flat square one) with KODI loaded and it works brilliantly. I have a FLIRC dongle and am controlling it with my Beo 4. I have a Beosystem 3 and it it's too much hassle to get the PUC table updated so I chose a Humax PUC from the list and taught the FLIRC that so it now works flawlessly.
I can play files stored on my PC and on my NAS drive and if friends bring over films on a USB thumb drive I can play those too. If you plug in a USB hub you should be able to use the FLIRC and a Wireless keyboard. I actually use the FireTV remote on my tablet for typing searches or Internet surfing.
Stoobie
