Which make Beolab 6000
Hi all,
I’m a bit confused, this set BL6000 I’m looking at have serialnumbers above 18xxx and should be mk2. But they do not have the silver amplifiers. Could this be a BL6002 instead?
Serial 21294279
Item 1682001
Type 6821
Hope someone can guide me in this. Thanks in advance.
Beolab 6002 are type 6832
If you have black amp. than sometning is not ok..or maybe old stock..
Thanks, this helps a lot. To my knowledge the mk2’s are from 18xx serials upgoing. The serial and black amplifiers do not match and maybe they are altered. Stepping away from this set.
