Which beogram?
I have some old records I would like to play from time to time. Which beogram should be the best investment, and will be able to interact best with my setup? I have a BS3000 as audiomaster, and a phono button on my Beo4...
Bart
To the BS 3000 you can connect a TT with build in preamp direct to AUX in, without preamp build into the TT you will need a preamp and the proper cables. Search the forum for Beogram with preamp
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks for your help? Which beogram is in terms of styling and functionality the most desirable?
Design is a mather of personal taste, I like the BG 3000 series (tangential tracking), where the BG 4500 has a build in RIAA, from a mecanics point of view i prefere the older radial tracking decks, simple mecanics and elektronics, easy to repair and even so, good sound, considering that most of saved vinyl today is in lesser than mint condition, I would go for a radial tracking BG and buy a new cartridge like MMC4, a new cartridge is a must in whatever BG you buy today (if not fitted from seller). But check the product list here and Beocentral, deside what you want, and go hunting, as you are in Europe, you have more choices than us over here. And as you are in Netherlands, ask Leslie on this forum, he has some decks that may be worth a try (if he wants to sell😁)
And keep us informed, we like to see where you go, and maybe you get the Beovirus, I started with a BG 2404 and now I try to get complete sets, with the corrosponding speakers.
Retired
Rock and Roll music
Collecting Vinyl
Generally, the tangential (linear) tracking Beograms are the most desirable.
The rarest of these is unquestionably the Beogram 4000, the first tangential tracker.
Very similar in styling and sound quality is the Beogram 4002/4004.
The next in the series is the Beogram 8000 and 8002, very precise mechanics and digital technology.
These two first "generations" of tangential decks are my favourites.
The next generation started with the Beogram 5005 and afterwards, essentially the same deck appears as the 5500, 6500, 7000, 3000, 3500, 4500, 8500, 9000 etc.
Unless you want to mess about with a stand alone RIAA pre amp and associated cables and hassle you are limited to one of the following 5.
Beogram 3500, 4500, 6500, or 7000 from the modern lightweight series or the Beogram 6000Quad from the heavyweight earlier series.
I think that the RIAA-question is kinda overrated. A preamplifier of reasonable quality can be bought for about 50 euros:
Hi Bart,
What styles/forms do you like most? Cubic like BeoGram 5000-7000, 4000 etc. or more flattened like BG4500/9500?
Here a high quality RIAA solution for older BeoGram turntables:
Agree with my brother in name, Søren, a preamp is, with the right cables, easy to connect I've had both my BGs connected to my BS3000 through preamp, no problem.
Retired
Rock and Roll music
Collecting Vinyl
Just my opinion: BG8002     Here a BG6002 impression
