Which B&O receiver offers
inputs/outputs on RCA jacks? I am looking for one which has RCA jacks inputs and outputs as well as pre-outs and main in on RCA. I like the styling of something like 6500 receiver.
Any help from this forum would be truly appreciated.
I am getting into B&O now, after getting a RX-2 turntable, someone lended me a cartridge, MMC5, to go with it, and it sounds soooo good and it is a turntable for me, just put a clean, record on and enjoy music, no more cartridge alingment or arm adjustment to wory about.
You would nont believe the kind of money I have spend over the years with turntable and cartridges, I wish someone had told me before about this B&O turntable.
Please help me getting a B&O Receiver and CD player as well let me know which ones are very good and reliable as I will be buying them used.
Cheers and Happy listening.
Hello Kalk and welcome to the world of B&O.
There are many options when it comes to Receivers and it all depends on what you have in mind for the future.
If you would intend to go for a small link later on I would even consider going for an Overture instead of a Beomaster 5500, 6500 or 7000.
Of course there is always the the option of a Beocenter 9000, 9500 or 9300 where you can also have the tape and CD functions.
If I were you I would first think how much I would like to spend and then have the optimum for this!
BUT trust me you have many alternatives!!!
If you want RCA connectors, you need the link. This comes in either a brushed metal finish or white. It has a full set of both DIN and RCA connectors - I use one for this very reason as it allows full remote control of my B&O sources via DIN and lots of auxillary connections as well. You can use it with an MCL2 link system so it is quite versatile and is also reasonably cheap. The amplifier in it is good and the sources that match it are excellent. I would consider swapping your link for a link as long as it doesn't cost much simply so you get remote control. The decks are otherwise very similar except the 5000 has a natty light. In my opinion, the 5000 is the best of the later decks, having a good radial arm and superb build quality. The link and similar tangentials are just not as nicely made. I also think it sounds better.
You need a link to get the most from the system though I confess to never using mine as it is not a main system so the timer is not an issue- I have given the white one away. The
Peter wrote:
The link is the best CD player that B&O made and would be something to consider later.
Just curious. Would that not also apply to a CD 6500 and CD 7000? Would a 7000 then not qualify as the best?
Regards,
William
Actually no - the CD5500 had the best motor - a slightly less well specified one was fitted to the late 5500, 6500 and 7000. Whether you can tell the difference is unlikely, but in principle, the first of the CD5500s are the best! 😁
I think you might be looking at something rather older, the Beolab 5000
The Bolab 5000 does this as well but I think is a bit esoteric! Picture of the Din connectors of the 5500
And the RCA connections!
Same for the Beomaster 5000.
 Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Very true and has a better pre-amp than the 5500 as well as a real pre-amp out (the 5500 is attenuated power amp out - cheapskates!) but the 5500 uses the Beolink 1000 codes which is a big advantage.
