Where is TURN function on Beoremote1 ?
all is in the Title ! ;-)
Do you mean for a motorized stand? If so, the command is Stand.
no TURN for ATAPE (K7)
If you can't find it, it's available as a command on the BLGW to map to one of the "CONTROL" commands on the BeoRemote One.
The Beo4 manual says that TURN is accomplished by pressing the center button (a.k.a. GO).  Maybe that works on the BeoRemote One too? Seems unlikely I admit -- sorry, I don't have my old equipment available to test, so I'm just guessing...  Presumably you have already tried P+ and P- as well as the backarrow (<--, a.k.a. BACK, left of INFO) and none of them worked?
Not found. But not check every Control. List is too long...
@ beojeff I don't have any BLGW
Not sure if it helps, but on the BL1000 TURN is achieved by pressing SHIFT then SOUND.  I don't have one, but perhaps you can get the BeoRemote One to do this?
Unfortunately no SHIFT on BR1...🙁
Yes, there is a SHIFT function, but it's on the "LIST for Beo4 Video" (if you enable it in the menus), not the one for Beo4 Audio.  Whether or not it can be used to change the following button-press if you have to access said button-press from the LIST button again as you must to get "Sound", who knows?
Trivium: The *reason* TURN was overlaid on SHIFT-SOUND when it was removed from the remotes was because the other function of the TURN button (besides flip-the-cassette) was to switch between sound tracks on a video tape or a multi-language TV tuner program in Beovision MV/VX 5000 days.
[Edit: Have you tried enabling the "Track" menu item in the Beo4 Audio List?  If I were an engineer, that's where I'd hide it: Track-1 and Track-2 is what the cassette (virtually) is, after all...  Yes, I know that *should* be the same as P+ and P- buttons, but since we're grasping at straws, there's another one to try!  Again sorry I cannot test myself instead of posting WAGs.  Your question has become a bee in my bonnet, because I bought a BeoRemote One BT to replace a dead Beolink 1000, so I'm gonna send a web-form message to B&O support, too.]
B&O Support says, "The 'Turn' command is unavailable on the BeoRemote One as it is simply outside of its capabilities."
