KMA wrote:
So the Avant's picture has improved with use? I am referring to your earlier observations, Moxxey:
Well, yes, but this is likely from the software update that was performed after I made that initial observation.
When the installer was here, I was comparing the channels and quality and posted the above as I was posting whilst he was in busy with finishing off the install.
Last thing he did was update the software, which also improved the motion issues I saw on Sky, which have mostly - but not completely - gone away. There are no outstanding issues using Sky on the Avant, that I can see. ie. I don't sit there thinking "that's a problem".
But we half-expected the motion and other issues to be software-related. As I said in the past, the installer was also a product tester and he said that picture rendering was so poor using the initial Avant pre-release software that it was laughable. So, it's definitely improved.
