What volume do you listen on your BeoVision?
I was thinking about how sometimes my settings aren't right, but it could be that im listening too low?
I generally listen to at 30 and movies at 40.
Should i be listening louder?
What volume do you listen?
Any answer will be useless, as there are so many factors involved: source of the signal and factory level, BV model, loudspeakers connected and level settings, distance to the BV and size of the room ...
For example, on my BV11-55 in the bedroom, volume setting at 35 in movie mode through the inbuilt speaker, I have to setup the BV7-55+BL7.6 from the living room at 50 to have the same sound level. Both sources are the same: a HUMAX Satellite decoder connected by HDMI with volume setting at the maximum.
Oli is right ... especially when you include the age of my πŸ‘‚πŸ» πŸ‘€πŸ‘‚πŸ»
We typically have voice at 48
And big movies at up to 70
i better turn it up then :-)
My BV6-26, 3m away, is usually set to 30 (sometimes, I crank it up to 36-38...). And that's enough to watch (and listen to πŸ˜•) TV at any time of the day.
NB: the volume of the external DVB decoder is set at max!
I sit 4.5 meters from my BV12-65, and BL18 pair in the lounge.
Generally, TV at volume 50-53, louder for movies (largely to hear vocals more clearly), about 60-65.
Music varies, depends on mood, but closer to 50.
My bedroom Avant is 3.5 meters away from viewing position.
No supplementary fronts like the lounge has.
Therefore not as powerful a setup.
TV at volume 40-44.
Hope that helps.
I like it louder than most, as a general rule.
45 year old ears, for the record.
68 and 72 year old ears at this end
7-55, bl 10 and 50.
Movie at 50-60
Music at 35-60, wife at home
Music at 60-90, home alone. No need for a massage chair😎
🐘 🐘 BeoNut since '75
That’s odd - normally both ears are the same age πŸ˜•
Excellent 😁
