What preamp for AV 7000 AUX input for TV
Dear all, I've successfully connected my Samsung QLED 7 TV via HDMI ARC/DAC/RCA to my AV 7000 receiver via AUX input. This works fine, however the output level is a little low. I can increase the volume on the AV 7000 / Beomaster 7000 of course, however when you switch to another native B&O audio device and forget to normalize the volume, your neighbors will be well aware of your new choice. So I want to use a preamp for the TVs audio output, but not sure what type I need. Most of the preamps I see are for Phono - so I guess they are not suitable for my purpose? Can maybe one of you experts point me to a suitable preamp? Thanks a lot for your help! Cyana
Hello, would a small headphone amp help? Between the DAC and the receiver.
Beofan for many years with a penchant for 1990s audio systems.
Hi pepps, I guess any active preamp helps as long as it does not mess with the signal. It's only hard to find one, that is not Phono and has an L/R RCA output. Do you have one in mind? thanks Cyana
Hello there, no nothing specific but as you may just need a little boost for that paticular item it seemed like it might help.
I totally agree, however can't find one. Either it's phono, or some hi-end stuff with tubes, that I want to avoid. The preamp stays hidden within a chamber under the TV, so no need for bling bling stuff.
Thank you for your efforts - I've looked for Topping products too now, however they are either rather expensive (+400 EUR), or battery powered with no RCA input/output. Cyana
Are you extracting the analogue audio from eARC? If so, have you considered an extractor which varies the output as discussed in this thread?
Hi Guy, thank you for pointing me to this thread. Yes, I'm using a ARC/CEC extractor and the volume control of the TV works - it's however pointless because the level is so low that you need to set the TV's volume to max and even increase the volume of the 7000 system for about 30% to have a good sound experience. That's why I'm looking for a preamp to rise the output level of ARC extractor. As for the SHARC-V2 8k eARC Audio Processor - I don't get it how it is connected to the Beomaster 6500 in that thread - it has a HDMI output, so this would require another ARC to RCA converter - or do I miss something here? thanks Cyana
As for the SHARC-V2 8k eARC Audio Processor – I don’t get it how it is connected to the Beomaster 6500 in that thread – it has a HDMI output, so this would require another ARC to RCA converter – or do I miss something here?
It does have an analogue output - actually shown as a headphone output. The analogue output is discussed in more detail here: It could be worth contacting the company to describe your setup and see if they have any suggestions.  The OP from that other thread had a good response from them.
