What is the latest software version for the Beosystem 3
I have software version 2.7, does anyone know if this has been superceeded and if so what the newer software does/fixes.
Cheers
Peter
The latest version is 3.0
Thanks for starting this thread Peter and the latest update, Keith. Is there anywhere on the site which shows the versions and what has changed between versions? I guess this is an engineer update, any experience of how much dealers charge for upgrades?
I too would like to know what was contained in the update, a list of supported products, aswell as where to find the system version,,, Please?
Well, as I understand it, the latest software update corrects an issue when an audio source is played in speaker mode 5 and the sound configuration was not saved for BeoLab 2's.
Apparently the key new feature of this update is the provision of full HD output resolution, also a BeoCentre 2 overlay menu.
There is also a new feature for the US market, not sure what this is however.
As far as cost for the upgrade is concerned, I guess this will vary from dealer to dealer, but is done with a software tool from a laptop PC like most updates these days.
Any news on if any third party DVD players have been added IR-control wise?
Great, thanks Peter,
Now itching to find out exactly what changes have been made to version 3 and what products are supported.
Has Apple TV been supported??
Just ordered a new BeoSystem 3 yesterday.
Do you think it will have version 3.0 installed from the factory, or should I ask my dealer to upgrade when installing?
RoMo
PS!
Planned to buy a pair of the new BeoLab 9 to go with the BeoSystem 3, but made a big mistake by also listening to BeoLab 5 (just to compare of course). My wife and I ended up choosing the 5'ers instead of 9'ers. Big difference is sound +++ (and cost ---).
So my advice to myself (for the future) is not to listen to better equipment to find of what you will be missing 😉.
I think you can be fairly sure that it will be version 3
