Hi Guys,
Does anybody know the differences between Beosystem 3 Mark I and Mark II-versions?
Regards
Hi Guys,
Regards
Martin,
Besides the very large number of software updates which effected both versions and the introduction of "Adaptive Sound Technology", the only core changes provided by the mark 2 I can note from reviewing the spec are:-
The Mark 1 version has "Type" numbers 9600 to 9612 and was sold between June 2006 and Dec 2008
The Mark 2 version has "Type" numbers 9615 to 9628 and was released around October 2008
Hi Keith,
I have Beovision 7-40 Mark III. It is a full-Hd Tv and I have software 5.08 which supports 24p. So I dont think (and dont hope) that your points is the differences between mark I and Mark II.
To my knowledge, the Mk III BV7 was released around the same time as the MK II BS3 is indicated above.
Possibly not coincidence.
Is it possible to upgrade a MK1 to a MK2?
If yes, is it worth it?
and the introduction of "Adaptive Sound Technology" ...
The introduction of "Adaptive Sound Technology" required a substantial change in
the hardware of the Dolby Surround Module (DSM)
- Mk1s must be retrofitted with a new DSM MK2 module and then the SW has to be
updated to offer "Adaptive Sound Technology"
- Mk2s are already equipped with the new DSM MK 2 module - and may/will need an
update to use "Adaptive Sound Technology"
- BeoVision 7-40 MK III/TV Type 9370-9384,9398 9456-9471 will need the DSM Mk2
hardware upgrade + SW update for using AST
- BeoVision 7-55 Type 9479-9495 & BeoVision 7-40 MK IV Type 9439-9455 (or newer)
will need just a SW update for using AST
Thanks!
But, what is Adaptive Sound Technology?
/Ola
Thanks!
/Ola
... depending on your listening/viewing-habits and the placement of your speakers
- either an "interesting gimmick" or "my dream becomes true"
Are they going to put this in other lcd tv's to in the future🤔
At present AST is part of /can be retrofitted to all BeoSystem 3 based TVs (BV7-40Mk3 & newer, BV7-55, BV4, BV9)
Let's wait and see what next generation TV-chassis will have to offer.
