What could be wrong with my Avant? 🤢
Uuuh - that’s a tricky one.
Don’t know if that will help, but it is the answer to one of your questions:
’If you need to reset your television to default settings, then bring up the REGIONAL SETTINGS menu and select another country.
You will be asked to confirm the reset. All settings will be deleted and you must go through first-time setup, follow the on- screen instructions’
as written in the user guide.
I don’t know if there is any other way to do this?
Beware - you will have to make all settings again, which can be quite a job.
So be sure to make notes/take pics of your settings before you go along.
P.S. I’d remove all connections before getting on with it.
P.P.S. This is something that I would only do, if the is no other ‘cure’ to the problem/s.
Thanks appreciate your feedback.Uuuh - that’s a tricky one. Don’t know if that will help, but it is the answer to one of your questions: ’If you need to reset your television to default settings, then bring up the REGIONAL SETTINGS menu and select another country. You will be asked to confirm the reset. All settings will be deleted and you must go through first-time setup, follow the on- screen instructions’ as written in the user guide. I don’t know if there is any other way to do this? Beware - you will have to make all settings again, which can be quite a job. So be sure to make notes/take pics of your settings before you go along. P.S. I’d remove all connections before getting on with it. P.P.S. This is something that I would only do, if the is no other ‘cure’ to the problem/s. MM There is a tv - and there is a BV.
Ok, the BeoSystem 4 version.
The Beovision Avant is based but not exactly the same as BSys4. This reset process is straight from the Beosystem 4. You may be lucky.
Otherwise, In your version some changes relate to its 4K capability. Its likely you need a call to service to reset this properly including all its capable resolutions.
I believe also that there is a video test mode that can be invoked or a manual test procedure to help. Both maybe of assistance.
Good luck, Beoaus.
Thanks, i have called them and now await their response
You mention "this reset process is straight from the Beosystem 4"... were you going to write what that process was (by your sentence) or was it more for my info?
Thanks again
Last night it fixed itself and i was watching Foxtel for a few hours and this morning again it stuffed up
I tried again this arvo with Hot Seat at 5 and at 5:40 it started to go.
