What B&O product(s) do you intend to buy in 2020? New or used, headphone, tv, speaker, turntable, system…?
The only product I may buy is the Stage, and maybe a new remote if that would be launched.Other than that I have all I need 🙂What B&O product(s) do you intend to buy in 2020? New or used, headphone, tv, speaker, turntable, system…?
In a new house so just bought a LG c9 65" and will add a stage and remote to that for the secondary living room this month. The room is not that large so kept it simple and everything will go on the wall.
If an eclipse v2 launches and follows the harmony logic (using a standard LG panel upgradable) then ill go for that in 55" for the main living room to pair with my lab 20´s. Currently there is a Beovision 11-40 there, which can move to the bedroom, but 55" is as large as I can go in that room and the TV has to rotate out from the wall due to the shape of the room and sofa position.....I am quite restricted with what works there.
I am kind of ready to upgrade the 20´s but theres nothing in the current range for me at the moment so no rush. 50´s are just too big for my living room so hopefully there will be a lab 20s size replacement in the next year or so.
Regardless, very impressed with some of the newer products and looking forward to seeing more.
It won’t work with any series other than a c panelThe argument is that the speakers are the worst in c panels and would therefore complement well with bo stageBeoSound 2 and BeSound Stage to go with a new 77 inch LG E Series TV. Beolab (8000 x 2, 2 x 1, 6000 x 4), Beoplay (A9, P6, H9 3rd Gen)
It does work, just not with BR1.
I'm using mine with E7 (2017 model) and very happy with it.
I am considering a Beoplay A9 (without assistant) and perhaps another Beoplay M5.
So what is holding me back?
[1] I am aware of the Airplay2 option, which is good, but I prefer the device streaming content directly from the source instead of having data going via a tablet, phone, laptop etc.
