WebMedia on my BV11's on the fritz... The BV11 seem's unable to sign-in for some reason.
When I switch to WebMedia (Beo4, Beo5 button or from Source list in BV11 setup menu) I get the normal grey rotating ring in the bottom left corner and then a lock icon inside for a split second before the screen goes blank apart from a message top left in very small font
"To complete Smart TV sign-in,please switch your TV set off and on again"
So dutifully I complied (several times including physically unplugging the TV etc.) with no luck whatsoever. Everytime I try to go to WebMedia, the same sign-in message.
So i was fiddling around with all the setup options to find an answer and under WebMedia setup, I found security settings which gave me this screen.
When I browsed to that screen with my laptop I simply get "Due to maintenance the requested page is not available" (perhaps someone could try the same link (https://nettv.corio.com/BlueportServelts/Blueporthome) and see if same happens.
I also went to the https://nettv.corio.com homepage which seems to be just a WebSphere portal but there is a link at the top that says Dashboard. Clicking on it from laptop gets you to a page with ""To complete Smart TV sign-in,please switch your TV set off and on again"
Seems to me that my BV11 no longer automatically signs in to this nettv portal (which appears to be some sort of back end for our Smart TV services).
- Any ideas on how to fix this?
- Do you guys think the issue is on my side (BV11, Internet connection / ISP etc.) or is on the nettv portal side (the due to maintenance bit indicates that)
Any thoughts?
