Wanted modification for Beolab 1
Hello!
I found a modification for the Beolab 1 made by Glenn Guillot (Beo Tech) its a 3steps guide.
http://www.beoworld.org/beotech/beolab1.htm
The problem is that there is only part 1 & 2. Part 3 is missing.
Where can I find this Glenn Guillot? I would like to do this modification, but I need part 3.
Have you guys try this mod, and does it work good?
179 views and still no luck to find Glenn Guillot.
If you guys have a smallest hint, let me now :)
Double post
G'day, i've done this modification (the improvements in sound are subtle, and possibly psychosomatic), what parts of the modification have you done already? It will refresh my memory. :)
Ah! There was no Part 3 :)
Add a beolab 2, mate :)
Did you already tried part 1 and 2?
I tried part 1 and iT really didn't make a lot of a difference.
Adding a receiver with room correction XT32 audessey did a lot more for me.
But I'm curious for part 2.
oh..... And there is no such thing as part 3.
I have not tried any modification yet.
Glenn Guillot says: Stay tuned for modifications Part III ;)
Thats why i haven't tried it, and I still have warranty on the speakers.
Desmo: Part 1 didn`t do much? thats to bad :( Glenn maybe didn`t do any part 3, its that what you mean?
Yep.
and changing The pots is audible, But it's not really doing good, because you are changing a whole range, not doing room correction, or finetuning The sound. The beolab 1 are actually very good, But they are really hard to setup, because they have a very small sweetspot and you end up with a out of phase sound.
try to download a audio sample for a phase test and make sure it's right. Thats making a whole lot of improvement.
Okey :)
I have tried som audiotest, but i have also moved the speaker and now they play much better.
The bass i deeper and the midrange sound really good now :) its almost like a new speaker!
thank you! Case closed ;)
