Wall mounted BV7-40. Anyone got one?
I am considering changing the placement of my B&O equipment and I am trying to source pictures of a BV7-40 wall mounted without success so far. It seems that because of its curved back its going to stick out at least 10 inches and that's before its even added to the wall bracket that tilts it. The 7-40 is not the right TV to choose if you want a flat against the wall solution I guess. Any thoughts and pictures appreciated. Thanks.
Simon.
Original B&O wall brackets
Or for alternative wall brackets  STB brackets
Don't forget www.stbrackets.co.uk !
Many thanks for the pictures and for your comments.
Hi Chris,
Well I am seriously considering it yes. Besides, I thought LCDs were quite light anyway? I am sure my walls won't have a problem holding it, they are thick masonary and would hold anything. I might get a BV4 instead which is a flatter fit and ofcourse plasma. Playing around with ideas at the moment. How is yours set up?
Simon.
I'll stick with B&O whatever I choose. Even though I know many other manufacturers offers better sets. Its the design concept I buy into. Its all going to come down to pricing but I'll see. Will keep you posted.
Simon.
My thoughts exactly.
