waiting new products
My home should be ready at the end of september 2008, and I will wait until the first week of september to order all my BO products, hoping new software or products in the next 2-3 months
I should buy
n.1 Beovision 4-65 hoping for new more contrast panasonic panels
n.1 Beosystem 3 hoping with full compatible bluray
n.1 Beomedia 2 hoping in Beomedia 3 or in Beosound 5
n.4 Beolab 3
n.1 Beolab 2
n.1 Beolab 7.2
n.1 DVD 2 hoping for a new version DVD 3 with bluray
n.2 Beolab 3500
n.1 Beovision 8-32
n.1 Beocenter 2 hoping for a new version
What do you think about the possibility that I could buy new products within september
max
BeoMedia 2 won't happen, let alone BeoMedia 3.
Why do you want a new version of the BeoCenter 2? They're fantastic as-is.
With September in mind,
1. BeoVision 4-65 higher contrast panels: Already happened. D10 ACM versions are on the market. No further updates in this time frame.
2. BeoSystem 3 w/ Blu-Ray compatibility: Yes, this is reasonable. If, for some reason it has not happened yet, though, it is software and will be retro-compatible.
3. BeoMedia Update: Not likely by September. BeoSound 5 & BeoMaster 5 are the update to this. Their launch date will almost certainly be after Christmas.
4. DVD 2 / 3 Blu-Ray player: Not in this timeframe. While anything is possible, expect to see Blu-Ray integrated into BeoVision 7s & BeoCenter 2s, not in a standalone player.
That, I believe, addresses all the issues you have with the items you plan on purchasing. If I were you I'd hold off on a BeoMedia or BeoCenter 2, but everything else should be a go. Waiting for another BeoVision 4 is senseless as we'll always be a generation behind Panasonic, and it really and truly does not matter in terms of the picture quality we'll deliver. If you cannot get past this disparity, buy a Panasonic plasma.
Hope this helps!
all these items will be available 2030!!!!!Lightning
Trip,
 I'm curious about your prediction for a blu-ray Beocenter 2. Have you heard of this from reliable sources? As I already have a BC2, I was looking forward to a stand-alone B&O blu-ray player.
Also, what are your thoughts about B&O adding HDMI 1.3 and 24 fps with the Beosystem 3 in the future? This has been a reason for me to hold off on buying a Beosystem 3 until B&O brings it more up-to-date with the market standards.
The BC2 with Blueray I consider very unlikely. Not that i do not acknowledge your status Trip, but they would have to HDMI enable it which means new drive and also a complete new base unit.
Since it's a few years in the market I would think rather then revamping as is they will put their money towards something new.
BeoJeff,
Those changes, when made, will in all likelyhood be software updateable for existing BS-3's already in the field, so I'm not sure that its worth waiting for, since you risk waiting long enough to enjoy the next price increase.
Russ
BC2 Blu-Ray: Very reliable. I would put its likelihood at 75% or better. Updating the portions of the Master Unit & Socket Panel necessary for the transition would be significantly less expensive than designing a new system, setting up manufacturing, assembly, logistics, etc. The "form factor" of a system is not just the shape, but the entire build process surrounding it. Additionally, Bang & Olufsen will not be designing a new form factor to handle physical media. A transition to a Blu-Ray drive will allow the BeoCenter 2 to finish out the era of optical discs with grace and give it up to a decade of vitality in the market-place.
As for the BeoSystem 3 update to HDMI 1.3, 24fps, this has been delayed a few times, but is coming to market very soon.
Indeed, a blu-ray BC2 would be ideal; however, since I already have a BC2 such a purchase would not be an option for me. I rather like the new form of the brushed aluminum, stackable components such as the DVD2.
Trip, would you expect the forthcoming Beomaster 5 to be similar in form to the DVD2 as a brushed aluminum, stackable component?
Since HDMI 1.3 is more than just a software upgrade, I'm just not prepared to invest in a Beosystem 3 until B&O gets it correct out of the box. Paying $500 for a service tech to come out and update the software would negate any forthcoming price increase.
