Volume control app Beolink NL/ML
Anyone know how to adjust volume on the Beolink NL/ML with the B&O app? The old Beoremote app I used before doesn't work anymore
Just a guess but wouldn’t you use it as you would other devices in the app?
Beolink as I understand appears as a device nl ml converter. Is that correct ?
Other devices such as an A9 this is how you adjust the volume.
Tap the device and when you do the device background fills out the screen to show you it’s the selected device - you can also see in the black area too.
Then tap the ^
Then control the volume
Does your BLC NL/ML have speakers attached to it ?
Yes, I use a Beolink Passive amplifier
I am not sure we are talking about the same device ...
Here is the new App (I am on the beta)
In the middle of the 3 products is the silver BeoLink Converter ... it supports PowerLink but I do not have any speakers attached.
The screen is showing all 3 units are linked in a group if I go to this view, and click on each rooms little speaker icon (I.e. not the X as that disconnects that unit from the group) I get the slider option to adjust an individual set of speakers within that room
Is this the sort of environment that you are enquiring about ?
I am curious there too.
Maybe he is refering to a BeoLink Passive (driving passive speakers) connected to the PL output of the Converter?
Or maybe the BeoLink Passive connected via ML to the Converter?
In the second case that would need an ir eye to be (volume) controlled....and can not be controlled via the app.
Yes, that's what I use.
Thanks - and it does not appear in the device list like shown by elephant?
@elephant
Is there maybe some setting in the converter for that - something that must be enabled?
