We need speakers for B&O Beocenter 7000(vintage, 1980's). Are they available? Or, is there an adaptor that will enable us to use RAC jacks (terminals)?
vintage speakers
No need to use non-standard speaker connections, the DIN-standard plugs were invented a long time ago.
The plugs are available separately, both as screw mount and solder.
Adapters for non-standard connections are also available.
But B&O made some excellent cables, that will fit both the Beocenter and the Beovox speakers, which in the case of the S45 mentioned above
has countersunk male DIN sockets at the back. Clever and easy.
Beovox S45 (type 6302 or 6312) would be a good choice though the Beocenter will easily drive larger speakers, such as Beovox S120 etc.
Thanks. I'll check this out
