VGA and DVI input
Hi Warren
Yes the Camera menu is a bit hidden!
It took me ages to get my beomedia sorted on the vga input but I got there eventually......have just taken delivery of Sky HD and guess what....confusion reigns again!
How do I know if the DVI input is slot 1 or 2?
I have tried both to no avail....
So I set either slot to DVI-D and CVBS to Decoder (what does that actually mean?). Then sure enough when I go back to the Connections menu I have the option to set the Decoder input to STB(DTV/DVI) but I get no picture ie the monitor is not selecting the DVI input which is coming straight from the HDMI output on the sky box (the audio is there via the scart).
Any ideas?
Many thanks
Mark
this actually turned out to be a problem with the DVI input card on the BV4 - tried a 50" BV4 the other day and all worked fine!
