Unfortunately I don't have any further information on this. But let me add one more thing to the story:
The wall bracket issue became "public" on the weekend before my V1 arrived, so I had to settle for the tilted floor stand as a quick backup solution. (Which I now really like and will stick to.). I took this decision because my dealer told me that the improved wall brackets should be available by July, and I didn't want to wait another couple of weeks.
To keep things safe, I'd advise you to take the hassle of exchanging the bracket since they should be available by now... maybe the part fixed to the wall doesn't even need to be changed at all.
Ah I understand. Well I have mine on a wall and don´t have a tilted stand at all. When the TV arrived there where no stands at all so I had it for a week or two without being able to use it. Then I got a wallmount but I was supposed to buy a table stand that they said was necessary to buy but I was able to get only the wall mount (for the same price also).
I am now thinking that I should probably have a backup tilted stand anyway for future installations in different environments perhaps. And regarding exchanging the wall mount I don't want to do the job for B&O/my dealer. I think it is up to them to tell me the stand needs to be exchanged (if it has to be). Perhaps they remade it because if it isnt screwed in completely it might fail but not if it is used properly?
If it in fact is really dangerous they should have called me by now, right? I am after all buying a B&O tv, not a samsung. The mother company is just an hour away from me so it seems weird that I should need to call them.
