V1 features and what´s working
I have noticed a few interesting things on my V1, or more like two interesting things.
1. The TV says "when a Bang olufsen dvd or blu-ray player" is connected that it will be controlled by the tv. B&O don't have a bluray player.
2. The TV says on information about the different led color/blinks that it might be in stand by, or recording a program. This makes me think it would be possible to record TV to a USB-memory.
Perhaps B&O cut this feature in last second, either way a shame since very common tv´s today have the feature. Maybe they cut it to introduce it on more expensive B&O sets with the same video engine? Or perhaps it will come with a software update later?
I would have use for the feature and I think a lot of people would like that also.
This brings me to a feature request. The EPG, which looks very nice, don't have a timer feature. In many other systems it is possible to navigate to a future program and put a timer on it. So the TV can change channel when the next program is on on that channel.
Regarding the Media feature in the TV I have tried it out with Plex Media server running on Mountain Lion and that works (a review said it did not work).
Another thing I was thinking about is that it is supposed to support both 2.4ghz and 5ghz wifi. My V1 can only see my 2.4Ghz network(they have separate SSID names). Using the AirPort utility from Apple I can see that it connects and establishes a speed of about 144mbit most of the time. This works fine but I am thinking about switching to ethernet but just perhaps. I have an Apple TV connected also and both have just 100mbit ethernet (not gigabit) so it would be possible to use a ethernet-splitter adaptor to get two ports via one cable. Not sure I have space for such an adapter inside the V1 however :)
Thats it for now :)
as a new customer (& forum member - Hello to all!), before purchasing my V1-40 I also had some thoughts upon a possible USB recording feature. Beocare answer as follows:
"Do not support USB recording and no plans to"
Still, in my case both the picture and sound quality of the V1 kept me from purchasing a Loewe Connect ID, which obviously features HDD/USB recording at a high level (twin tuner!). I'd really appreciate a recording option (even via paid upgrade), but maybe such a feature is planned to be found on future models with the new video engine...
Other things I'd like to share:
I had big troubles streaming video content via wired ethernet. Seems that the inbuilt LAN interface is too slow - I've also placed a support request on this one... using the WLAN option there's no problem in streaming, everything is way faster. And I didn't have any issues using wired ethernet with my old streaming box (aside from the fact that it couldn't playback MKV/H264 content).
Finally, EPG: my V1 keeps "forgetting" all EPG data after a standby. I'm using DVB-S2 in Austria. No idea whats wrong here, but this is really annoying. Maybe you're having similar problems?
/MIK
PS: my V1 arrived last week, and all the joints between front and rear case have been protected with paper strips accordingly... so no paint marks at all on my unit... but I had to go for the table stand due to the wall mount recall issue, but I like it now
144mbit or 144Mb/s ?
Only my Macbook and MacMini get up to that speed
MIK wrote:
/MIK
Hi there, and welcome to Beoworld!
I'm a new customer to B&O as well, having purchased my first serious B&O product, a 40" V1, for which I am awaiting delivery any day now, with bated breath!
I'm very interested to read that B&O appear to have quickly responded to some production or packaging teething problems, re some units being unpacked and found to have scratched paint - seemingly at the joins where the 'hinges' of the front and back meet, and can scrape together either during shipment or assembly - by placing paper strips to ameliorate any such happening.
I'm so hoping my TV will have had the same packaging modifications and not present any problems re the paint finish or otherwise to sully my first new serious B&O purchase!
I only saw the table stand on a 32" model, but did like it nonetheless.
Any knowledge as to what the actual problem was with the wall mount?
Kind regards
John.... 😐
Thanks for the welcome!
It took me a lot of time and consideration to finally settle on the V1, but now I'm really impressed and satisfied with my decision. And if it stays that way, I'm quite sure further B&O gear will follow...
Hopefully your V1 will be without any issues as well. I ordered mine at the beginning of June, and it already had those "protecting" paper strips. Glad that they really try to react quickly on such user concerns/issues. Also the support is very nice, and really intends to listen to the customers... as I've been told, the EPG issue mentioned in my first post might get resolved in a future software update.
As for the wall mount I don't know any further details. The only thing I remember is that for the revised wall bracket you now have to specify the preferred rotation axis location before ordering, whilst the first version didn't have that limitation.
Best regards,
MIK
Best regards,
MIK
Oh, I have thought about this and I think that I now know what the problem is. On the wall mount I have the stand has two long bars that are not mounted on the mount in packaging.
This is because they are not the same length, you see, one pin is longer than the other that goes into the tv because of the tv construction. It is the same on every stand (table stand etc) but on them the pins are not removeable.
On the wall mount the pins/bars are screwed onto the hinges that are on the wall mount. They might be too weak to withstand the weight of the TV and now I am a bit more scared that they might fail at any time..
Michael wrote:
Best regards,
MIK
OUCH !!
Now you/we know what the problem is/was I suggest you ring your dealer tomorrow !!
I checked yesterday and it said 144MB/s as you can
elephant wrote:
OUCH !!
I am not sure this is the actual issue but since MIK said the new stands only seemed to have the difference that you need to specify orientation first that made me think of this. The bars are screwed together and I think this can be a quite weak construction but I have no idea.
Too bad that the new stand needs to be either right or left since one might move and need a different orientation later on. They could have made the bar design different. They could have moved the unscrewable part longer out so the bars attatched to the mount was longer and you only screwed on the last few cm that differentiates. That would have given the same flexibility and also provided more stability since it is already longer into the tv.
Unfortunately I don't have any further information on this. But let me add one more thing to the story:
The wall bracket issue became "public" on the weekend before my V1 arrived, so I had to settle for the tilted floor stand as a quick backup solution. (Which I now really like and will stick to.). I took this decision because my dealer told me that the improved wall brackets should be available by July, and I didn't want to wait another couple of weeks.
To keep things safe, I'd advise you to take the hassle of exchanging the bracket since they should be available by now... maybe the part fixed to the wall doesn't even need to be changed at all.
