V1-32 and IR control issue
The IR control of my V1-32 progressively stopped working. First, I couldn't turn on the TV with any remote (Beo4/6). Had to use the BeoLink App instead to control the TV. However, after a few minutes, the IR control was again possible.
This went on for a few weeks, but now the IR control is no longer possible, even after a few minutes on. I can only use the Beoremote or the BeoLink Apps. Of course, I have tried the remotes on another V1; it just works fine. I also did several mains reset, but didn't help.
Has anyone had this issue? Can the IR control be dead while all the rest just works fine?
Thanks.
Guy
I had this issue with my V1-40, not able to use the remote anymore, only the app. Dead IR receiver in TV, they fixed it under warranty and on the invoice it was mentioned they had to change the motherboard.
I'm afraid you have to bring the TV to your dealer and hope the repair will not be that expensive.
The motherboard! Well, this will certainly be expensive[:\'(]
Yes...the same happened to my V1 32 last week...
Really disapointed
Glad to read this (sorry for you guys but helpful for me) as I was about to pull the trigger on a secondhand V1-40. I might reconsider!
Likewise BAND'OH!
Have we dodged a bullet here?!
Did some investigation and found that the problem could be solved by replacing the module IR Receiver & Room Awareness (PCB58). It's a small module which is located on the top on the TV.
Really?
It's easy to do but where can you buy this PCB?
This one?
Your dealer will be able to provide you with the module.
