Hi All,
Would it be possible to use the Apple TV, that would then be connected directly to the A.AUX of my ouverture and all of it being controlled using the iphone? Or does the TV have to be on?
Hi All,
Not sure ... I would be guessing that there is no awareness of whether the screen is present or even powered on ...
However, I don't see how you could navigate without visual awareness !
I would think it would work fine. I can listen to music from the Apple TV in a link room with no TV and works perfectly using an iTouch.
Thanks for the responses.
So Razlaw, would you do something like, LINK + V.AUX, then use the itouch?
So would you connect the apple tv solely using the HDMI cable, or both the HDMI cable to the tv and then the Analogue RCA stereo audio cable to the ouverture a.aux?
I've been doing this for the past couple of years, controlling with my Touch with the remote app. Only disadvantage really has been updates, when I then have to connect to a TV to navigate the menu to install the update. On one occasion I thought my ATV had developed a fault as it wouldn't respond at all. When I plugged it in to the TV it was telling me there was an update available. Previously I hadn't been able to see this.
Hi Kokomo.
Thanks for 'the update', haha. That's ok for me, because if I got one, it would be used for both TV and 'remote' use. It's just that I want a way to listen to my MP3s (not using my PS3 to stream) and without having to switch the PC on.
Also, id love to be able to listen to music at night, or in the morning whilst getting ready for work just by pressing a few buttons...
Can I also now ask a very specific question, can the Apple TV be used to just stream music from my Western Digital World Edition (NAS) drive that has an iTunes server? Because 160GB is nothing!
Firstly, forgot to mention that you will need to have a screen available to setup the ATV initially.
As for your specific question, how much music have you got?? Do you mean that you want to stream music from your WDWE drive to the ATV?
My depth of knowledge about separate drives is not sufficient to answer that I'm afraid. But if you are using iTunes, I can't see any problem streaming all your media to the ATV. Don't know enough about external drives to answer any more I'm afraid.
I assume though that you don't need to have your PC on for this which is something you say you don't want. I thought your original point was that you just wanted to use the ATV!
Thanks again. Basically, I don't have loads of music (around 80GB) but with photos and videos, that 160GB quota will get full very quickly.
I'm just thinking about the future, if i get the apple tv and it gets full, whether I can carry on using the music stored on the WDWE hard drive that is constantly on (sleeps when inactive) and the apple tv that is the same. Both would mean music on demand with no pc needed and no need to switch them on manually.
I agree that with photos & video things would fill up, BUT I thought your original query was about listening to music via your ouverture.
I appreciate that you are looking to the future, but in that case and if you envisage viewing your media, I would have thought you should be going down the route of connecting to a TV. It all depends on your needs. At this particular time I don't want to watch anything from my ATV (this may have something to do however with the fact that my TV doesn't have HDMI or component!). Of course things may change in the future, but if you just want to listen to music, the ATV is and will be fine.
True, but I want the option of both.
Using the ATV via the BV7 for Photos (not really movies since the PS3 is amazing)
And, via the A.AUX (+ Ouverture) to listen to music.
