Using Passive b&o Speakers via powerlink
Hello there,
Is there a box that converts power link signals i.e.: a rear out from an avant, that i can connect a pair of passive speakers?
Thanks in advance!
yes there is, its called a beolink passive,
a small box about the size of a shoe box thats an amp so you can then come out of the avant using mk2 powerlink and use any type of passive speakers.
they only do left and right so if you want surround sound then you will need 2.
ray
Yes, the official beolink passiv box. Works since years perfect with a pair of Yamaha in my kitchen.
