I have connected my Beomaster 5500 with a DIN cable in TAPE2/AUX to the T1611 converter and then the master link cable to my beovision 10 and then the 2 beolab’s 6000 in the beovision. This works perfect music and sounds great.
Only 2 issues.
1: I first have to put on my tv (DTV, or something) to put on the radio. I can’t just press in the radio button on my beo4 remote or master control panel. After i put on the radio the tv goes on black screen, witch is good. But i would like to have it directly with the radio button.
2: I can not change the volume with the master control panel only with the beo4 remote. (I only can use this when i am using my headphone). Maby because it can not communicate with the beovision 10.
Hopefully can someone help me fix this ‘problem’s’, if its even possible.
James
