Using B&O App on a Mac with Apple M1
Hi everyone,
I'm sure lots of you already know it but I have not found any thread related to this.
With the new M1 processor, Mac computers can run the B&O iOS app seamlessly. Version 3.9 currently running on my MacBook Pro
As long as the developer (B&O) allows it. So download it now while they allow it.
Why would they not allow it? An app is to be used!
BV11-46, BV8-32, V1-32, BS2, P6, A1, E8, BR1, Essence
Apps was possible to side load before, now they have to be downloaded from the App Store - and the developer has to make it accessible from a Mac. They may chose not to as it is not designed to be run on a Mac usually (with untested screen size etc).
I installed it directly from the Mac App Store, it appears in the Apps for iPhone and iPad section.
Works very well.
